Audi A4 05 quattro 3.0 V6 Coolant Temperature Sensor
Coolant Temperature Light had come on about 2 weeks ago. First thing I did was check the coolant level, everything was good it was just right above the minimum level. Second thing I checked was to see if the coolant tank had any crack or leaks and nope it was perfect. I drove the car back from a trip I was in and during the trip I kept my eye on the temperature gauge. It stayed right in the middle the entire way so, I knew the car was receiving coolant.I figured at this point the coolant temperature sensor was out so I got it replaced. I knew to reset the computer you take the battery connection out so, I took the negative side off the battery and left it for about 15mins. I then put the battery back on and the coolant light still came back on. I don't know what could be wrong a this point in need of help.
You have a 2005 A4, so why are you posting a new thread in the Q5 forum, go to the proper forum for your A4, as I told you in your other post.......
I understand, I apologize for posting on here. I thought in the previous post when he posted the link he meant I could also comment there. It's my first time on here, I would like to delete the post but I don't know how.
You have to ask for "Edit Rights" by clicking the link and posting " I would like Edit Rights".
https://www.audiworld.com/forums/feedback-11/official-i-want-edit-rights-thread-2748703/
jjlax
A4 (B7 Platform) Discussion
10-15-2013 04:45 PM
banana s4
16
11-30-2006 05:37 AM
SO i get the coolant light, does that come on ONLY when coolant level is low or even if mixture is..
white90+hibredS4
04-22-2004 03:52 PM
