Coolant Temperature Flashing Light
Coolant Temperature Light had come on about 2 weeks ago. First thing I did was check the coolant level, everything was good it was just right above the minimum level. Second thing I checked was to see if the coolant tank had any crack or leaks and nope it was perfect. I drove the car back from a trip I was in and during the trip I kept my eye on the temperature gauge. It stayed right in the middle the entire way so, I knew the car was receiving coolant.I figured at this point the coolant temperature sensor was out so I got it replaced. I knew to reset the computer you take the battery connection out so, I took the negative side off the battery and left it for about 15mins. I then put the battery back on and the coolant light still came back on. I don't know what could be wrong a this point in need of help.
Do you have a scan ?
http://www.ross-tech.com/vag-com/cars/applications/a4s4.html
https://store.ross-tech.com/shop/cat/VCDS
https://parts.audiusa.com/a/Audi_200...G/1397080.html
For $199.00 you could own your scan tool, almost pays for itself the first time instead of going to the dealer for a scan, you will need a laptop.
The $199 will get you the 3 # VIN option.
https://store.ross-tech.com/shop/vchv2_ent/
Update: I ended up checking out the coolant level sensor, it appears that the sensor is built into the coolant box. I unhooked it to check it out and hooked it back on and the coolant light ended up going away. I guess it wasn't attached properly before or I got lucky but thanks for the info!
majinruu
Q5/SQ5 MKII Discussion
10-03-2017 06:45 AM
quattroman
10-14-2000 11:07 AM
