Dash cam
#22
Also, I use this tool to help.
#23
I was able to get the wire in. Maybe your wire is too thick?
https://www.amazon.com/gp/product/B01L8GHB7O/
I got a Viofo A119 dash cam.
Thanks.
#24
I used the tools to pull out enough to tuck the wire in. I didn't pull all way out. It was a bit tough to pull on. One tool to pull and at the same on another tool to push wire in.
#25
Where did you get the power from? 12V outlet or fuse box? If it is the fuse box, which fuse should I choose?
#26
why dont you take your car and dash cam to a reputable car stereo shop? I'm 100% confident they could give you what you want without tearing up your interior (or showing fugly wires)
#27
Would you go?
#29
I have most of the tools to pry out the trims, however, there are mot many shops in my area have experience deal with this new Q5.
They told me that they had lots of experiences how to install the dash cams but what I could see inside the shops were people using the fingers pulling out the trims. Beside, you never know what they broke and they would not not allow you to watch they were doing to your car.
i installed dash cam to my another car because I researched the info before doing the work. Since it is your own car, it is always good to collect information from others to ensure what you are doing before taking pieces apart.
Agree?
Agree?
#30
I had a chance to visit the dealership and spoke to the technician regarding the dashcam installation. He told me it was dangerous to tuck the wire behind the A-pillar without removing the A-pillar trim. The reason was once the airbag deployed during a car accident and the dashcam wire would hit your face due to it was not secured and blocked the way of the airbag location.
He suggested removing the A-pillar trim and routed the wire along with the existing wires behind the A-pillar and secured them together. However, once the A-pillar trim was removed, some of the plastic clips must be replaced and not be re-used.
I spoke to most of the local audio / dashcam shops in my area and they did not know anything about the replacement of the plastic clips and removal of the A-pillar. Most of the shops told me they would tuck the wire under the headliner and run along the a-pillar and connected to the fuse panel.
Did anyone remove the A-pillar, route and secure the dashcam wire? Did you disconnect the battery before doing this job?
