SQ5 Transmission Behavior
#11
I am a new 2018 SQ5 owner and this is one of the first things I noticed about the car - a noticeable "dead pedal" feeling when accelerating quickly from a dead stop. It is most evident in "D" Comfort mode - "S" and Dynamic (with Start/Stop OFF) do seem to help a bit - but not 100%. This is my first Audi (coming from a Acura MDX) and it is a bit concerning. Aside from this issue, the car is great.
As others have mentioned on this thread, it is not "turbo lag" - the throttle just does not respond like it should (even if I mash the pedal from the git-go). I have a service appt at the dealer this week for them to take a look at it. It feels like a throttle/transmission programming issue to me, so hopefully it is something that could be corrected with a software update/tweak.
#12
Now that you mention it, when I did my test drive I felt what I assumed to be hill assist from a stop. After than I felt it a few more times, the impression that the brakes were activating from a stop and slight delay in "letting go" of the throttle.
#13
Mine does it too, I think it’s part of the Fuel, Transmission map. In Dynamic it’s a fire breather so I assume it’s the normal program trying to be smooth and avoid lurching. If you ease into it and then give it full throttle it accelerates quickly. It’s easy to change to Dynamic if you feel rambunctious. On the other hand it could create a safety issue if you were in a hurry to avoid an accident. It took me a few weeks to adjust to it and now I hardly notice.
The general procedure was something like this:
1) Press start button into accessory mode(do not start car)
2) Press throttle pedal all the way down for at least 5 seconds
3) While holding throttle pedal down, press start button to turn off car
4) Release throttle after holding for a couple more seconds
5) You should hear the system clicking and resetting.
I've tried this, and while I do hear some whirring and clicking from the throttle body, I also hear the same noises when I just turn on the car (without starting it), then within a few seconds turn the car back off again. So I am not sure the procedure is really doing anything. I will see if it affects the actual pedal/throttle response later today.
#14
I may give that reset a try after I'm through my break in, which should be soon. To me, it seems that the real dip comes in just after the first shift (from first to second or second to third). Since I don't have the gear indicator while in D, I'm not sure if the car is starting out in second, so I'm not 100% sure which gear it goes into that really causes that big dip in power. After that first shift, things are much more linear and don't have the same major dip in power.
#15
#16
#17
In doing additional research on this "lag", I came across a number of other threads in the forums on other model Audis (and really, any car with drive-by-wire that "adapts" to the driver seems to be affected). Some of those folks saw improvements by performing a "throttle body adjustment" or reset of some kind.
I used to do it with an old Infiniti G35. Porsche has been nice enough to do it to my Macan a couple of times when it's been in the shop.
AvramD
25
01-04-2004 06:51 AM
