Volume control stopped working
The volume control on the center counsel stopped working today. Has anyone else experienced this? Not sure if it's firmware or hardware related, but turning off the car and restarting did not help.
Have you tried a full reset of the MMI system (hold the Nav and Radio toggle buttons up and push the center ****)? I had an issue where my music quit playing altogether and the screen went blank and a reset brought things back to normal
2) When you push down on the volume control, is the mute symbol showing on the MMI screen or the dash screen if it is set to the radio function?
So it appears to be firmware / software. It's now working again, and I did nothing other than turn off the car, let it sit for a bit, and then restart it. The entire control, including the joystick and mute, were disabled but the steering wheel controls still worked.
Glad to hear it's resolved and it wasn't anything major.
Everything on the car runs on the CAN bus that links the modules. Sometimes crap happens which causes a module to lose sync. If you turn off the car, lock it, wait 5 minutes it goes into full sleep mode/shutdown which tends to reset issues like you found.
Jes thinkin.........
Thanks, Wires!
I have both an 18 sq5 and 18 q7 and it’s happened on the 5 once and on the 7 about 10 times (call it once a month). Reset fixes it. Volume control on the steering wheel still works
FARJR
04-02-2014 05:44 PM
frenchie_pm
01-25-2012 05:25 PM
sloopercat
11-27-2002 08:22 AM
