2010 TDI Glow plug light and DPF light
I am located in Delray Beach Florida
TIA
Any autoparts store will scan it for free, but to get more info you need a VAG scan tool, the store will just have a generic OBDII scanner.
Sure sounds like may be a clogged DPF from mileage and description of symptoms, but you need a VAGCOM capable scan tool to read ALL of the trouble codes. If you don't DIY on your car, a good one is the OBD-Eleven, which integrates with a smart phone; DO NOT purchase the annual subscription required to do higher level coding/mods, and such, and it will function very well as an inexpensive code reader for you. Similar, bluetooth 'dongle' scanner types for this car include the Carista, as well. Of course, if you DIY, you will want the tool that works best; VCDS, by Ross-Tech.
BTW, DPFs can be cleaned, if they are still serviceable otherwise, and there is normally a cleaning port located on the DPF for just that purpose. The Audi dealer and their ilk will normally just tell you the price for a new part, and that it is 'required', etc. You'll figure it out; the scantool is your path to the light (aka 'the truth'), as most third parties see nothing but $$$$ signs when you drive up. Find a reputable, indie repair shop with diesel experience, etc.
If you replaced DPF 50k miles ago, it shouldn't be clogged IF everything on the car is working perfectly, AND the IF the DPF's automated regen cycles have been running successfully, and IF you are using the correct oil type (specifically designed not to clog up the emissions system's bits) etc. You aren't going to know much until you scan the car for fault codes. It could be just a temp or emissions sensor gone bad, and it often is when you lose turbo-boost. Scan the car and let it tell you what's wrong with it.
