Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Problem: iPod reinitializing
Old Oct 23, 2007 | 12:42 PM
WUMS95's Avatar
New Member
Default Problem: iPod reinitializing
Does anyone here have the problem - either after getting back into the car and starting it up, or even, at times, in the middle of driving, where the iPod has to "re-initialize" and begin playing the songs from alphabetical order?
My iPod works fine, and I assume that the AMI connector wire is faulty and/or there is some MMI software glitch.
Anyone else have something similar?
Old Oct 24, 2007 | 01:44 AM
Ashleey's Avatar
Default Had the same thing...
with my ipod using my alpine system in my A8, but not with the Dension 500 in my Q7. Thus, I suspect it may not be the ipod but the AMI. Best advice is to update your ipod with latest software and reload all your music and see if it helps. Also, disable all the contacts management stuff etc. Mine is now fine for the time being with occasional problems with the Alpine.
Old Oct 24, 2007 | 02:11 AM
996CAB's Avatar
Default Re: Problem: iPod reinitializing
I get same issue however I just presumed that is the way things are meant to be - does not bother me at the moment though.
Old Oct 25, 2007 | 07:58 AM
cutthroat's Avatar
Happens with mine 2-3 X / month.
Old Oct 25, 2007 | 07:55 PM
Q7Q7Q7's Avatar
Default Reinitializing and song sequence issue
I hsve tried three different iPods in my car (I have had the AMI since March). I too have occasional reinitializations for no apparent reason. One problem I have noticed is that when I when I drill down to an artist and play a song from an album, the song name matches the song being played. But when I choose "all" from a given artist, I get a different song than what I see as being selected.
It is not a problem with the iPod (I have this problem on any of the 3 iPods I have tried) because when I play all with headphones on, all is fine. Same when I go into iTunes to see what is going on. I have done the wipe out and reloading of songs, updated software route, etc....but still the same problem.
Any experience this before?
Old Nov 10, 2007 | 04:19 AM
Double_Dip_A6's Avatar
I am now experiencing the problem, but have determined that is because the iPod is not being charged when the car is turned off and it remains running until the battey dies. A quick check would be the next time you see the initializing screen remove the ipod and see if it stays on .... I bet the batter shows low
Pharmsoup
Sep 16, 2015 07:57 PM
JCGMS1
Q5/SQ5 MKI (8R) Discussion
Oct 2, 2011 07:28 AM
afouralex
A4 (B8 Platform) Discussion
Nov 25, 2008 07:58 PM
Kingttr
Jan 10, 2008 09:39 PM
wonb07q7
Q7 MK 1 Discussion
Nov 10, 2007 04:15 AM
