2017 Flex pipe broken again after 30k miles
#21
You could do it yourself. This is the easiest r&r exhaust job. Like you mentioned, the hardest part eas removing the old clamps. Once that is out, everything is a breeze.
#22
You have already know that these ultra-sensitive pipes needs to be tightened at a sequence per audi instruction. Make sure the technician is aware. The flex pipes needs to be at a relaxing state and not to be forced upon.
I was just curious about the general cost and what I’m saving myself.
#23
Well today I found that where the crack is someone had already welded a different crack. You can see it aft of the crack.
so now I’ll need to grind it all off and start over.
also can someone explain the logic I using three different types of fasteners on the small cover.
#25
Got the exhaust off and lookie what I found. Not only was the weld repair bad but the mechanic did not even bother taking it off. It is nearly broken through the entire circumference.
A little weld will do ya!
I will stop drill the cracks and tack everything into its place then weld with stainless as needed.
I am not sure of the grade but it looks like 409 since it has telltale leopard spots.
I have compatible weld wire.
The top two pics are the underside and the lowers are the top of the tubing.
#27
according to the TSB you need to tighten things in sequence, I’m sure they were not.
#28
I over-welded which is often not a good idea but I went across the main one with a few beads. I think it will provide extra strength. Not pretty but it will work. It’s a tough place to work since the pipes are close. I added some high temp paint for a little extra covering.
#29
I took off the tips to clean them and found more corrosion and cracking. First off. The NORMA clamps were disintegrating. I called them and it is too much trouble getting an exact replacement. So I got some on amazon made of 304 stainless compared to 409 as the originals are. I changed the nut and washer to stainless. Here’s what I found on the right side: the tip under the clamp was cracked all the way through so badly there’s no saving it. I found a used one on eBay. Second there were many micro-cracks on the main exhaust tube. I stop drilled them and will weld/grind them smooth. The left tip only had three cracks so drilling them should help. Nothing on the exhaust tube. Who knew this would bring out so many defects?
#30
OP here, I got the car back yesterday. I provided all the parts (front right muffler/flex pipe, mount, gasket = ~$400). My guy charged $51 for labor. I gave him a copy of the Service Bulletin which he said he followed. And problem solved, no noise or rattle.
I don't expect to have to deal with this again anytime soon, since we're likely to get a newer Q7 in the near future. But then it will be some other problem, I'm sure.
Thanks for all the advise!
