2018 Q7 'wanders'
#21
#22
And don't forget you set Auto Lane Assist to early or late intervention through the settings. So if it bounces around too much, first set it to late intervention and see if you can cope with that. IMHO, late is far better than early.
#23
Do you find that it does not deviate as far from the lane center when set to late? Thanks.
#24
Why is it thant nobody would simply tell you to turn off "lane assist"? It is simple! Just push the button on the end of the turn signal stalk. That is if as a "race car driver" you know where the turn signal stalk is located (LOL).
#25
That also deletes the Lane Assist function. Kind of like removing the engine to reduce noise
#26
pinballing down the freeway....
Regarding the steering; I traded my 2008 A6 (and a 2000 A6 before that ) for the 2018 Q7 and the first thing I noticed was the difference in the steering between the two cars... With the A6 I almost did not have to think about driving the car down the freeway. The steering feedback was so precise that I could feel every minor directional movement and could almost drive with muscle memory. With the Q7 I don't get the steering feedback it is like I am driving a video game... Guess I will get use to it...
#27
After a number of my complaints, Audi and the dealer performed a wheel alignment, sensor alignment and apparently changed some constants in the driver assist system. That made a marked improvement in the lane assist performance.
#28
report on driving mode changes etc to cure wandering
. dynamic mode does exactly what it says it should...tightens everything up, both steering and suspension, etc. This give the illusion that this wandering is under tighter control. but, unfortunatley, it's still there, just communicated differently. i like this mode but, as always, it's the compromise between wanting a softer ride with the other benefits of the 'dynamic', a mix not possible (i have this on a ferrarri too, where it's a 'package' deal)
. i can't tell any difference by turning off pre-sense
i will persue the lane-assist idea tomorrow and report back. thanks to all
#29
conclusion, findings
i'm replying to a few of the posts regarding this wandering. i tried changing to dynamic mode and turning off pre-sense. i did NOT yet try turning off lane-assist...i will do that too....the result?
in Dynamic mode, the overall tightening-up brings a level of illusion to the control aspects of the steering, but fundamentally, i don't think actually affects tracking precision.
so, bottom line: with all the sytems calibrated, and alignment performed, and nannies turned off where possible, it still has this imprecise tracking i'm calling wandering. i'm concluding, also based on the lack of forum input re ppl having similar problems, that this is endemic to q7's and that folks in general don't regard it as a problem.
thanks all
#30
OK, here's what i've found. there is no way to turn off 'lane assist' at all. you can only change it's sensitivity. so that function is always 'enabled' but i have it 'disengaged' so i believe it should not be a factor in the wandering dilemma (however, the audi service manager says that three 'systems' are operative all the time. i WAS able to turn off pre-sense completely, but that's about it. so i don't really know what else is actually funtioning that may affect steering).
thanks all
thanks all
