Any idea how much gas consumption when engine is running?
#11
I do, and I also have a placard that I place in the window starting that the temp is being monitored remotely, the dogs are safe, and my cellphone number to call for any problem. This to avoid some passerby breaking out a window to get the dogs out.
#12
I hope you have some kind of remote temp monitor in the car so in case the engine or AC quits you will know about its before your dog is dead.
#13
#14
That said, I can't really recommend this setup unless you are very tech savvy. It took some fiddling with settings to get it to work, especially setting up the hotspot and FreedomPop has really lousy support. You could use the in-car wifi if you're still paying for that (I'm not), but I think it only works with the ignition on.
If you do a web search for temp monitoring for RVs, you'll find all-in-one devices offered that will cost more per month but easier to set up and potentially more reliable.
#18
There are wireless thermometers that you can get that work via an separate RF channel and have a range of about 200 ft. I used to use one of these, but too often I was seated in the back of the restaurant and didn't get a good signal. Hence the need for a system that works over the cellular network so you are able to read the temp and get alerts even if you're miles away.
Prachatice
S6 (C7 Platform) Discussion
16
05-29-2018 07:11 PM
Matt E.
01-03-2005 06:09 PM
gh0st
07-28-2004 02:51 PM
EdP
01-06-2001 06:45 AM
