A/C Not Blowing Cold
Old 02-09-2018, 09:54 PM
deckhand's Avatar
Default A/C Not Blowing Cold
Have any of you experienced issues with your Q7's air conditioning system? My wife's 2017 Q7 all of a sudden starting blowing ambient air. I initially thought maybe it was a setting issue, however, after trying everything (Max A/C, recirc, coldest setting, etc) still no luck? I am probably going to have to take it in (dealership is a couple hours away) but thought I'd ask.
Old 02-09-2018, 10:09 PM
deckhand's Avatar
Oh, I forgot to mention.... there is a unusual slight hissing coming from the vents when "a/c" is initially cycled on.
Old 02-10-2018, 02:07 AM
Banned
Greg in JaxFl's Avatar
Hissing could be a loose or disconnected vacuume line. Or something may not be allowing the compressor to run. Other than checking fuses the dealer needs to take a look.
Old 02-10-2018, 07:50 AM
GBMILTON's Avatar
I'm going to put my question here as it is a general discussion of the A/C:
Today I turned the heat on, the red light comes on the A/C button. I intended to turn the heating off as the engine was not warm up enough and pressed the A/C button again. The light turned off but the fan was still blowing. Honestly I couldn't find anything in the manual. Did I accidentally find the outside air switch or what? Thanks
Old 07-05-2019, 05:24 AM
danno6's Avatar
Curious as to the resolution to this issue (AC blowing ambient air). I am having the same problem, I brought it to the dealer, they replaced a "pressure switch seal" and recharged the system, but it is happening again.
thanks
Old 11-28-2019, 11:10 AM
audisession's Avatar
I realize this is an old thread but any insights on this ?
Old 11-28-2019, 11:17 AM
3Kulits's Avatar
Try this. Just make sure to press the "USB A" look alike see pic (under the AUTO) to be solid .
Mariociri
03-16-2015 03:21 AM
audiq5_808
Q5/SQ5 MKI (8R) Discussion
12-07-2009 04:01 AM
technopimp
04-05-2005 07:38 PM
GSK
07-06-2004 12:45 PM
sohcrates
11-19-2002 09:00 AM
Quick Reply: A/C Not Blowing Cold
