Dashcam installation
#61
No, I just left it there. There's enough friction with the black padding (which does not seem to be conductive) and the module is so small and light, I don't think it's going anywhere.
#63
I also understand why Rick had to get a tap but didn't use it.
Just to be clear, you guys both got it from Amazon and it came with fuse attached: https://smile.amazon.com/gp/product/B01LXC2329 ?
Even spytec is selling it as bundle with a fusetap.
Dash Cam Hardwire + Fuse Kit - Mini USB
http://www.spytecinc.com/media/catal...wire_kit01.jpg
#64
#65
Also, the inline fuse on the SpyTec kit is redundant if you are using a fuse tap.
#66
I forgot to post pics of the camera itself after install. Here they are. For the exterior pics, I had to turn on the flash to be able to see it, which is why the pics look so filthy. Also, it is not nearly as visible from the outside as these pics make it look.
#67
We all know flash magnifies every bit of dirt and dust so don't worry about it. Also the USB jack is forcing you to leave a bit space on top, otherwise people would end up mounting it flush with headliners, then it would be impossible to remove the dashcam. Sort of blessing that the USB port is on top. I know I'd screw up and put it all the way on top by headliner... LOL
#68
#69
Did you have to fiddle with the low voltage cut-off 's dial to make it work right or is it just plug and play?
rsilvers mentioned adjusting the voltage and setting it up and soldering it, but it looks like you simply ran the adapter through it and that was it.
If we want to use simply switched source (and not mess with mirror cover), can we use one of the other fuse slots (preferably the empty one closer to center that you mentioned) and skip the low voltage sensor? I am afraid I'll short things trying to connect all this stuff in there. It doesn't look like you disconnected the battery before working in there, did you?
#70
I assume he had to adjust the dial to get the voltage setting correct... That's why i went with the other one that had the digital display... easier and more precise...
