Door locking issues
#11
If your vehicle is equipped with soft door closing mechanism, hitting the close button (keyfob or door) before the mechanism has a chance to pull the door shut, will not lock doors. The best indicator that doors didn't lock is the lack of the chirp. Also, it seems that sometimes for whatever reason the soft closing mechanism does not pull the door shut all the way. I had an interesting experience once, when I leaned on my door and it popped unlatched - not fun at highway speeds. I guess it's best to just slam the doors shut.
or are you saying regardless if the door is close completely or half way, the soft close still engages? Why would it engage if the door is completely shut?
#12
I don't have issues with the soft close though, soft close works fine. My issue is the car won't lock, even if all doors are completely shut.
My $.02, take it with a bag of salt if you like.
#13
No, what I'm saying that it appears from the outside that the door is CLOSED, but it's NOT, hence the computer won't LOCK it. The only thing that I could figured that would cause it (in my case) would be the soft close doors, as the mechanism is responsible for COMPLETELY latching and pulling the doors closed. This wouldn't happen in the vehicle without the soft close doors as they would just bounce back to latched but not closed position as there would be nothing trying to pull it shut.
#14
Can’t lock the car….period.
Hey folks, started having some random issues with my 2018 Q7. One day coming back to a parking lot, opened the passenger door with my hand and the convenience feature. Car unlocked, the door opened and the alarm went off. I took out the key from my pocket and hit the unlock button and the alarm stopped. Since then the car will randomly not lock all doors, whether I press my finger on the door handle or use the key fob.
When I use the key and lock the doors, sometimes it will lock and the beep will come on. Other times it will blink the turning signals like it's locking, but will not beep. I can hear some doors lock, but the passenger door will not lock. So I have to wait, unlock the car again, wait like 10-15 seconds and try again, and it will work.
It's very random and seems something to do with the passenger door.
Also when I unlock with the key, it unlocks the driver's door and I usually press unlock button a second time to unlock the other doors, however the unlock button seems not to be doing anything after the driver's door is unlocked and doesn't unlock the other doors. Usually have to wait 10-15 seconds and try again.
This issue just started happening recently. I took it to the dealer and they said they found a fault code and that the door would go into sleep mode or something. So there was a TSB they applied which was a software upgrade and was supposed to fix it.
I drove the car home from the dealer, later went to pick up dinner, parked the car, got out of the car, press the lock button, again I hear doors lock but no beep. I go check and the passenger door is unlocked. I waited 10-15 seconds and tried again and it locked with a beep and all doors were locked.
Anyone had similar issues?
20VTURBOA4
A4 (B7 Platform) Discussion
12-09-2019 07:42 PM
