Drive System Malfunction?
#11
I have had the same issue with my 2017 Q7. Has happened 2 or 3 times over the last 2.5 years. Seems to happen when I really hit the accelerator hard when the car is stopped. I always turn off the auto start/stop and the car is in Sport mode at the time. Like the OP, so far it goes away and does not return when I turn the car off and wait a few minutes.
Paul
Paul
#12
Just an update, since I first got this warning at the end of August it has not come back on and the Q has driven fine.. And in my case, I was in sport mode but wasn't accelerating hard just driving at a normal pace when it happened..
#13
It should have a code logged. It could just be a communications issue on the CAN bus though that would clear itself when you turned the car off/on. If it becomes a re-occurring issue, then there is an underling fault condition that would need to be addressed.
#16
Had this happen today... hard acceleration from a light... in S mode... started to accelerate then an immediate loss of power and the engine was really rough... pulled off the main road and engine smoothed out... Stop/Start disabled itself and got a warning on that too ( I had put the transmission back to normal D mode) OBDEleven indicates misfire with cylinder 1 and also something about direct injection malfunction with cylinder 1... Once I restarted the engine, the error light cleared... wondering if I need to take it in of just watch it and mention when it goes in for service... anyone else have the rough engine after the light came on?
#17
#18
Thanks for the reply... Start/Stop automatically disables when in S mode... I usually leave my Drive Select in Auto... are you saying while in S mode press the disable Stop/Start switch and it might prevent the misfire?
Thanks!
Thanks!
1stq7 (10-03-2020)
#19
So I had this happen to me several times im my 17 at stoplights and the track. All under hard acceleration .At the track I was in dynamic and I kept on getting that failure on hard acceleration from a stop. I eventually tried turning off auto start/stop manually even though dynamic said it was off and it didn't do it anymore. Haven't happen to me since I always turn it off when I decide to hard accelerate from a stop. I'll say give it a try and see if it works for you. If the issue persist take it to the dealership.
#20
I had this happen yesterday. I was starting a u-turn from stop and accelerated hard due to oncoming traffic. The warning came on halfway through the u-turn and the Q7 felt sluggish. I pulled over, turned off the car, got out of the car, locked doors, unlocked doors restarted it and all is fine. Traded the Q7 today for a new Cayenne (was already planned before this issue). We had too many problems with this Q7. I am done with Audi again at least for now (last break from Audi was 13 years after a problematic 1999 A6 Avant).
