kick for rear door to open
#11
I've had better success with using the kick motion (key with you) and then taking a small step back. The dealer specifically explained to step back as the sensors will not let the trunk open if you are too close. Hope that helps!
#13
#17
Please post what was fixed when they're done. A copy of the repair order would be great.
Mine hasn't worked for quite some time. My dealer worked on it for a while and didn't find the problem. But since I've done some coding, they wouldn't spend any more time on it without charging me.
#18
First the motion is not "kick open" its slide ur feet in parallel to the ground.
to elaborate ur letting ur feet off the ground 3 to 4 inches of the ground and keep that same 3 to 5 inches and slide ur feet in under the trunk and back in.
to me this seemed to work every time!!! good luck
#19
they did nothing. they said it works. the service manager came out and made it work. I tried it a couple of times and it worked. as soon as I left the lot and tried it again it stopped working. they said its 'a quirk of the first year with the feature'. yeah, like the graphic/camera glitch on the 360 degree camera. right
#20
Stefano Scalia
03-18-2007 04:00 PM
MatthewZ
06-13-2002 04:41 AM
