OBDEleven
#11
Too everyone getting fault codes. Its fairly common to see this on new cars. Pretty good chance they are faulty due to low voltage from weak batteries and from the engine break in. I also had 4 faults of the 3,4,5,6 knock sensors. They all happened at once at the same time lasting for a milli second.
I would clear any faults and check a few days later before taking the car to the dealer.
#12
I received mine and was easily able to enable the PDC
I cannot however open coding or adaption for Adaptive Cruise Control #13
I get a "Description Data Not Found" error at the bottom of the app.
This is to enable the menu for Default ACC Distance in MMI
Enable ACC Default Distance In MMI (VCDS 16.6 or newer required) - Allows you set the default distance
1. Auto Dist. Reg 13
2. Adaptation - 10
3. Select "Distance basic setting option" in dropdown
4. Select "On" from New value drop down
2. Adaptation - 10
#13
Hoping the group can help. I signed into the app using my ID/PW, entered the activation code and turned on PRO mode, pressed CONNECT and after a while it reported that it could not connect. (My android device bluetooth is on.)
I tried a direct bluetooth pairing from my android device to the OBDeleven. It sees the OBDeleven's mac address. I select that address and press "pair." It attempts to pair for some time but eventually gives up and says it cannot communicate with [mac address].
Nowhere does it ask me to input a pairing passcode or anything of that nature.
There is a red light on the unit and a blinking amber light.
My android device can pair with other bluetooth hardware, so not sure what is going on.
Any thoughts?
Any thoughts?
#14
Any thoughts?
Any thoughts?
What Android device do you have?
#15
#16
Will be interesting to see if it works.
Would you be able to do a factory reset on your tablet, or maybe a bluetooth settings reset if there is such a thing on Android?
Here's a FAQ that might help from the OBDeleven site:
FAQ about device usage. | OBDeleven
#17
Thanks for the links. I'm very reluctant to do a factory reset as I don't want to lose the apps, which took a while to get loaded and set up since Kindle doesn't natively allow Google Play.
By chance do you need to have wifi/internet access during the process? I do recall that my wifi connection was very very weak (I was outside in my driveway).
#18
#19
Anyone know what this error could be. One of many errors, but this is the only error that has occured more than once.
Predictive route data signal error.
Frequency count is now at 5 and seems to be increasing. On another note, was able to easily change the lane change signal from 3 flashes to 4.
#20
