Rattling noise in sunroof?
#23
For me, I apply Armour All at the area in the center of the sunroof, where both pieces of glass meet. I tilt the sunroof and apply it on the rubber seals of both pieces of glass. That's my troublesome spot every 5000 miles.
mbs (04-30-2021)
#24
Thanks for sharing that. So far, mine only rattles after a cold start for the first 5 minutes. Hopefully it stays that way.
#26
In my case, I had the Tech for 30 min one day for a ride diagnosing another problem. I asked him what he does to get rid of the noise in every service, he tells me he uses armorall where the rubber seals meet. Especially the area behind the driver seat and tilt the sunroof.
#27
Just out of curiosity; do you think the rattle is more likely to appear with use of the sunroof?
I don't use it very often and might avoid opening it up if the rattle would get worse.
#28
It depends on what the problem is the sunroof. You can ask your dealer to lubricate the sunroof to see if that solves the issue.
#29
I always start noticing the noise after I close the sunroof. And then after a few days, it'll stop.
Dr. Tinnitus (05-10-2021)
#30
I think it gets worse with opening it up. I think that's when the rubber seals get separated. My guess is that the seals dry out and make noise when they rub. You can sometimes hear it it when u push the sunroof up with your hands when closed.
