Secret MMI screen for '17 Q7
#11
Thanks. In previous versions of MMI, you could access many different settings via this green screen and red screen. I understand one of these screens you need in order to disable the video lock on the Nav monitor so your passengers can watch videos from the pop up screen. You could do this just by pressing a certain sequence of the MMI buttons.
#12
Carista still doesn't work
I just downloaded a beta version Carista OBD2 3.0 (300011) and it says no available customizations are available for this vehicle. That was not the best investment I've ever made. $40 for the Carista adapter and $20 for the Pro Version of the app.
#13
#15
There is no more green hidden menu in the MIB2 (2017 models) units. Everything is done via coding, adaptations or its coded in the eeprom.
#18
Cat Herder
my HEX+CAN works mostly. I have been unable to complete the lane assist coding however, and have been told by people in this forum it's because of incompatibility. I ordered an OBDeleven to verify with, since it's so cheap.
#19
2018 Q7, I can confirm this, there seems to be no way in VCDS to activate the ole green menu, at least in 5F>Adaptation. Interesting.
One thing, there are A LOT more channels in the sub menu now;
https://forums.ross-tech.com/showthr...3-e-tron/page3
(scroll down to 5F)
#20
Yes, in the 2018 Q7, true, 3 channels don't work, I'm using Hex+USB and VCDS 18.2.1
