Tires getting louder?
#11
I got off those Pirellis at about 20k miles. The road noise was killing me. And it's my wifes car. I don't drive it much.
I think the only other tire that fit was a Goodyear. I was skeptical, but they are super quite. A bit softer. Even my wife noticed the difference. Much happier on the skins.
#13
That's why I keep mine at 32psi. 99% of my driving is 3 people (equivalent adult size) or less. The Pirellis are wearing well and the ride is comfortable. Likely when the time comes I will replace them with the same. The problems that people have had with wear and chunking on the Goodyear scares me. So far I have been happy with Pirellis on three different cars.
#14
#15
I am not sure that tire chunking is brand related. I'd rather think that it is something caused by vehicle alignment/suspension/steering/tire inflation problem. I know a few Pirelli-haters who will not switch to Pirellies even if they will come 1/2 priced - for that very reason you will not switch to Goodyear. I, myself, once dealt with premium Michelin Latitude Tour tires which started to chunk really bad at 8/32", while Goodyears were giving as smooth and perfect ride as one can wish for until they were at 4/32".
#16
@superswiss, Thank you for the heads up... I had no idea... Will be dropping my pressures and probably enjoying a slightly smoother ride... I checked my manual and the values are bit different (although same for light load) Thanks again for sharing!!!
#17
My P+ has Goodyear RF on 20" wheels. I started hearing whirring noise at 29K miles, also noticed some chunks on outer edges on two tires. Dealer said I am not eligible for the edge chunking TSB (need to be >= 8/32, mine are <= 7/32), but they still recommended me to switch to Pirelli as the TSB says.
#18
I hit 22k on 20" pirelli's as I pulled into work today, I had them rotated by an independent shop last week and they said they still look great, but I felt they've gotten louder the last few months. I rotated them at ~6500, ~13k and ~21.5k I'm kinda planning on just getting new ones around 30k but we'll see.
I feel like I'm cursed with tire pressure as soon as I monkey with it, I'm constantly doing so, so I'm just hoping to avoid all that, i have no idea what they're at and I'm not inclined to even check it. Hear no evil, see no evil.
#19
That's a pretty bad attitude. Tire pressure needs to be checked regularly and adjusted and the TPMS needs to be reset. At least once a month, every other week is better, especially if you have temperature swings. Tires naturally lose air. The oxygen molecules escape through small pores in the compound. It's not unusual to lose about 1 psi per 4 weeks. On top of that, every 10F degrees in temperature change is another 1 psi loss or increase. TPMS is there as a last resort to alert you if the pressure is really low. We are talking 20-25% low as required by law, so by the time the TPMS goes off you've been driving around on underinflated tires for a while most likely. That affects your mpg, tire wear, handling and safety. Tires are the most underestimated equipment of a car. It's the only thing between the car and the road. Ever seen tires explode on the highway or the aftermath? That happens when folks drive on underinflated tires. Underinflated tires heat up much more than they should and eventually that can lead to tread separation and blow out. The other day I was driving back from LA and was about to pass this BMW. Just when I was coming up on his side, his rear left tire blew. Tread separated and started rolling towards me. I was able to accelerate to avoid being hit by it. The tread kept rolling behind me and eventually went off the road. Please don't be that guy.
