Winter tires for new Q7?
#31
That's the same seller I got mine from. Very quick shipping & good customer support via e-mail. When I asked, they told me that the wheels would use the OEM R14 ball lugs. I take that with a grain of salt since they're not Audi experts, but maybe Larry can weigh in. When I get ready to change over, I'll get with my guy @ the tire shop & verify if I need R13's.
I decided to just go down to 20s since I hate the look of small wheels on a vehicle as big as the Q7 and where I am, we don't regularly get 4 foot blizzards & the roads get plowed fairly quickly - plus, those Blizzaks are pretty aggressive, much more so than your average "all season".
Also, in your PM to me a while back, you said the offset was 33mm but this listing says 35. I thought this was the same exact wheel as yours?
Thanks, Cadx6.
#32
So the specs I listed are all okay for the Q7? What does Hub: 66.45 (57.1 as needed) mean? Do I have to tell them if I need 66.45 or 57.1?
Thanks, Cadx6.
Thanks, Cadx6.
The listing I bought my wheels from said their offset was 33 but after seeing all these other listings from the same seller, I'm beginning to have my doubts. I can't see 2mm making that much difference though. We test fit one wheel at the tire store & there was plenty of caliper clearance. Again, maybe one of our wheel experts can confirm.
#33
Sorry if this was covered before but for those of you who got full replacement tires. Are the pressure sensors(TPMS) required as well? Will the car freak out without them or do you also get tires with new sensors?
#34
Paging LarryV and Jalf
LarryV and Jalf,
When you have a spare moment, could you please help me with my questions (post # 29 in this thread)?
Your help/advice is greatly appreciated.
Thanks!
Thanks!
#35
Kind of nice not to have to spend all that money.
#36
Going with 19s
After giving it a lot of (maybe too much!) thought, I have decided to get the 19s. If the smaller size makes even a little bit of (positive) difference, I think I'll want it.
Tires will be 255/55/19.
Still deciding on whether I want the wheels from Hartmann (ACH Tuning) or Ebay. Hartmann's website seems to suggest only their 20" option will work with the 4M Q7, but I'm going to call them and confirm.
This forum has been a great help, so whatever I end up doing, I'll be sure to report here.
#37
Just got the 20" winter tire/wheels mounted from the dealer today. So far the ride is quiet compare to the 20" stock run flat tire. My Q7 is ready for winter.... Let it snow.
FYI... I used the OEM bolts that came with Q7 on the Hartmann wheels. The front fit without issue. For the rear wheels the dealer had to add a 5mm spacer since the bolts are a few mm too long.
#38
Interesting about the rear lug bolts. - thanks for the heads up.
#39
I had almost decided I was getting the 19" but I wanted Hartmann, and upon speaking with Skylar at Achtuning (Hartmann distributor in the US), learned that the only Hartmann that will fit (is load rated for the 4M Q7) is the 20". So I'm back to 20" now. Also learned that I'll need R13 bolts, the ones that are 30mm in length. I think he may have said the 27mm will also work. These are the ones I'm getting, R13 BALL SEAT (17MM HEX) NICKEL, 14MM 1.50 X 30MM
Did you use the Audi center caps from your summer (OEM) set, or buy those separately as well?
Also, I see you're staying with the OEM tire size for your winter set, 285/45/20. I'm considering going a bit narrower, either 275 or 265.
Question for you, and others (Cadx6, jalf, Larryv, etc.) - If you have a 20" wheel, can you use any 20" (meaning xxx/xx/20) tire with it? Of these Nokian options listed below, I'm trying to decide what to go with. Any thoughts are appreciated.
255/55R20 110 R XL
up to 106 mph, max load 2340 lb
265/45R20 108 R XL
up to 106 mph, max load 2200 lb
265/50R20 111 R XL
up to 106 mph, max load 2400 lb
275/40R20 106 R XL
up to 106 mph, max load 2090 lb
275/45R20 110 R XL
275/50R20 113 R XL
up to 106 mph, max load 2540 lb
#40
255/55R20 110 R XL
265/45R20 108 R XL
265/50R20 111 R XL
275/40R20 106 R XL
275/45R20 110 R XL
275/50R20 113 R XL
255/55R20 110 R XL
265/45R20 108 R XL
265/50R20 111 R XL
275/40R20 106 R XL
275/45R20 110 R XL
275/50R20 113 R XL
Tire Size Calculator - Tire & Wheel Plus Sizing
