ECU questions....
You can use the WR, however, it will not run the Fuel FV and will not use O2 sensor....
Same connector is used, so if you swap few pins around it is possible.
WR does run more advance on the ignition so might be slight performance gain, you will still need the WR cam to take full advantage of the setup and get rid of your cat for full conversion.
HTH
HTH
Fastscirocco
Audi Original "S" Cars
11-05-2008 05:15 PM
The Dog
07-09-2004 10:14 AM
Hokie - STI avant
10-28-2002 01:44 PM
