Are these the correct H1/H4s to buy for a 1983TQC
Old Feb 25, 2009 | 04:03 AM
  #11
ralleyquattro's Avatar
Default Yes and no, if you buy mounting brackets and the matching grill and trim pieces, yes, otherwise no
If you need the grill and trim pieces I have many sets and can part with one..
Old Feb 25, 2009 | 04:18 AM
  #12
racingiron's Avatar
Those look like the correct flat lamps, but you'll still need brackets.
Old Feb 25, 2009 | 06:57 AM
  #13
Shavedquattro's Avatar
For the flat Cebies? I want a pair Brandon.
Old Feb 25, 2009 | 08:42 AM
  #14
Berserker's Avatar
Default The brackets are there, they are plastic
I'm using the plastic brackets on my UrQ right now. It's three plastic pieces per light vs. the later one metal piece. All came off an early CGT in a junkyard in Germany when I was last there in 2003.
Old Feb 25, 2009 | 10:59 AM
  #15
4x5x5's Avatar
Default Re: NEW? Ahahahahahahahaaaaaaaaaa. Good luck even finding a decent set used....
Not one to argue with ones in the know but..... I have put Hella lamps on Cibie bodies and vice versa with no ill effects. Most, if not all internals are compatible. SS clamps are available and fit both lamps. I have run across at least 5 different versions of the lamp housings and most changes center around the adjustment mechanisms. 3 arm, 4 arm, 2 arm and **** and of course the electric ones. Any one need spare motors, let me know.
Old Feb 25, 2009 | 01:59 PM
  #16
urq20vt's Avatar
Default By "lamps" do you mean reflectors?
Yes, IME some of the stuff "kind of" fits like lenses, and you can crimp the stainless clamps from Cibies to fit Hellas to replace the plated steel clamps(not a bad idea IMO),but the only stuff that fits right, adjusts properly and gives the right output is when all the components match. I'm not sure how to get reflectors to swap properly... YMMV. If it works, cool...
Old Feb 25, 2009 | 04:24 PM
  #17
4x5x5's Avatar
Default Re: By "lamps" do you mean reflectors?
By "lamps" I mean the housings. The only structural diff I find on the lenses is the gasket depth. IIRC the Cibie channel is deeper than the Hella making the swap tough if you don'thave the right gaskets. Just pulled Hella reflectors and the mounts mic out at the same distance etc as the Cibie. Broke a mount in the process, boy are the old one brittle, but usually spreading open the mount points on the reflector, (there are 3 relief cuts on each mount point)adding some warmth and some lube and you can lever them out to swap in new ones. (If you can remove the adjusters from the back of the lamp, then removing the reflectors with the adjusters attached make the work a bit easier on the workbench. 1 mount is in a fixed point to the lamp body, 2 are adjustable and one is unattached)Checked a set of NOS reflectors I have and the measure properly to fit either Hella or Cibie lamps. I believe left and right reflectors are also swappable as long as you remember to swap the corner mounts as needed. Each reflector has 1 (of 4)open mount spaces depending on the intended side of use and will need to be changed accordingly. The corner fill plates seem the same as well.
Dilema
A7
Jun 28, 2018 07:20 PM
EvanUrS4
17
Sep 2, 2010 10:27 PM
gimiluv
Feb 23, 2004 12:16 PM
mike-lur
Oct 12, 2001 06:06 PM
s4soldier
Aug 27, 2001 10:04 AM
