Hawk brake pad installation issue?
Hi Guys, I need a little help here with an 08 RS4.
Does anyone have experience with installation of Hawk performance ceramic brake pads (HB609Z.572)? I chose these to balance dust and perfomance. My car is a daily driver and not tracked.
I have my car in the shop for pads and rotors and the tech is telling me the wear sensor on these pads is in the wrong place and it "will get cut off" when going in the caliper.
I called both ECS Tuning and Hawk directly and they tell me that they have sold plenty of these pads and have had no issues - the sensor wire should slide right through the caliper. These pads are specific to the car they tell me. I'm not experienced in changing pads so I'm caught in the middle of this with no personal experience.
See the attached pic from the installer showing the new pad with the OEM pad and the difference in the sensor wire location.
Should this be an issue?
Thanks.
Thanks.
AudiWorld Expert
I went with Centric to keep the dust down.
Problem solved. I reordered the pads and had them sent overnight. Second set worked fine. Turns out the wrong pads were in the box with the first set - despite the box having the correct part number.
I'm up and running again. New brakes, new tires, refinished wheels - and my wallet is a lot lighter!
Did you have ceramic pads on before? I switched from a semi-metallic to a ceramic on my last car and it tore up the rotors beyond repair. I was told you are supposed to turn the rotors before switching compounds as the rotors become 'impregnated' with the the brake pad compound.
....Then the Audi dealer told me the tolerance for the rotors on the RS4 makes it so they cannot be turned. Anyone else come across this?
There's not much "meat" on the rotors to allow turning them on a brake rotor lathe before the minimum thickness is reached. Another approach (for about the same cost) is to have a machine shop use a surface grinder (normally used to reface flywheels). It does a honey of a job and leaves a nice cross-hatched surface just like a brand new rotor comes with. It should take care of any pad build-up.
pentosinjunky
03-06-2007 11:19 AM
ToddM
07-20-2001 10:50 AM
