RS4 (B7 Platform) Discussion Discussion forum for the B7 Audi RS4
No luck searching this forum or the Wheel and Tire forum for info on the
Old 12-27-2006, 04:44 PM
Victoryroad's Avatar
Default No luck searching this forum or the Wheel and Tire forum for info on the
Tire Mobility System. If it works to get one safely home, does it destroy the tire pressure monitors? Wouldn't a portable air compressor be better? Of course, a torn sidewall negates both, so I guess the only solution is to travel with a spare and jack if away from home. Since I do not plan to race on the road, another 60 lbs. or so in the trunk can't be that noticeable.
Old 12-27-2006, 05:25 PM
RS4abob's Avatar
Default Read your Owners Manual and you will find.......
that the stuff in the can in your trunk is of a kind that dosn't mess up the pressure sensors. They specifically tell you NOT to use the commercially available stuff from parts stores for that reason. Also, there IS a compressor in your trunk as well because the stuff in the can doesn't inflate the tire.
Lots of other interesting stuff in the Owners Manual :-)
Bob
Old 12-27-2006, 06:00 PM
thanks
JoeS4
New England Discussion
12-18-2007 05:36 AM
Gary@Ronal
06-03-2004 05:18 AM
Gary@Ronal
12-20-2000 12:42 PM
Gary@Ronal
12-20-2000 12:39 PM
larryV
11-16-2000 06:03 PM
Quick Reply: No luck searching this forum or the Wheel and Tire forum for info on the
