Removed Sirus-Audio disappeared from ipod
I just removed my sirus module and the audio disappeared from my ipod. I can still see all the listings from my ipod but just no audio. Otherwise, everything continued to work. What could be wrong here? Is there something I can do at the sirus connection to make the ipod audio back again? Thanks.
This is pure conjecture....
From what I know Audi used the XM/Sirius tuner harness for the CD changer audio pass through. If the Ipod is rigged in the same way (audi wont let you get the cd changer with the ipod option) then removing the sirius tuner will hose your ipod.
Also if you need more room, that plastic shelf comes out. Its a royal PIA to get the the thing out have to peel away carpet and undo like 4-5 screws/bolts to get the thing loose otherwise you break the bottom bracket. Once you take out the shelf on the upper deck of the shelf there is a place to mount your sirius tuner. I recomend two people for this job one to hold carpet the other to undo screws. If you cant find someone to help keep some small construction clamps around to hold the carpet back. If you ever need to muck with it be ready for the same PIA to get to it. That upper deck on the shelf was the original spot for the sat tuner on B6 models. There is also a plastic clip/mounting bracket for that spot you can source from your local parts dept or someone who may have a spare on the b6 forum.
Other alternate is to use a huge square of self sticking velcro and mount it elsewhere.
One more option....
Is you can find pin out for the sirius tuner on audiworld or navplus.us and then try to jumper the wiring harness with some short lengths of wire.
did you change your VAG coding to reflect the removed SAT tuner?
You need to tell the system you removed the tuner.
Perhaps that is your issue?
STG 56 (Navigation System) -> Coding -> Function 07
0?xxxxx: Model
1 - Lamborghini
2 - Audi A3 (8P)
3 - Audi A4 (> 2004)
4 - Audi A4 Cabriolet (> 2004)
5 - Audi A6 (< 2004)
6 - Audi TT (> 2007) (sw US 0150+, EU 0500+)
7 - Audi R8 (sw US 0150+, EU 0500+)
0x?xxxx: Diagnostics for front speakers
0 - activ
1 - inactiv
0xx?xxx: Sound characteristics
0 - linear
1 - Audi A4 (> 2004)
2 - Audi A6 (< 2004)
3 - Audi A4 Cabriolet (> 2004)
4 - Audi TT (> 2004)
5 - Audi A3 (8P)
9 - Bose Soundsystem
0xxx?xx: Telephone/telematics
1 - no telephone (supply voltage for microphone actively)
2 - Mobile phone preparation (Temic - Speisesp. Microphone inactively)
3 - Mobile phone preparation (Cullmann - Speisesp. Microphone inactively)
4 - Mobile phone preparation (Nokia - Speisesp. Microphone inactively)
5 - Telematics Europe (supply voltage microphone inactively)
6 - Telematics US (supply voltage microphone inactively)
7 - Base plate diagnostic capable with comfort control
0xxxx?x: Options I
1 - default
2 - Digital-Radio
3 - Satelite-Radio
4 - Satelite- and Digital-Radio
5 - AUX in (Euro sw 0650+)
6 - AUX in and DAB (Euro sw 0650+)
0xxxxx?: Options II
1 - default
2 - TV-Tuner
3 - CD-Changer
4 - TV-Tuner and CD-Changer
5 - Multifunction Steering Wheel
6 - TV-Tuner and Multifunction Steering Wheel
7 - CD-Changer and Multifunction Steering Wheel
8 - TV-Tuner, CD-Changer und Multifunction Steering Whee
0?xxxxx: Model
1 - Lamborghini
2 - Audi A3 (8P)
0 - activ
1 - inactiv
0 - linear
5 - Audi A3 (8P)
0xxxx?x: Options I
1 - default
2 - Digital-Radio
3 - Satelite-Radio
0xxxxx?: Options II
1 - default
2 - TV-Tuner
3 - CD-Changer
Re: The iPod/CD changer audio is routed via the Sirius tuner - you need to bridge the connections.
Thank you! I found the pins from navplus and bridge 3->6, 4->7 and 5->8 and I have audio from ipod again.
SJB2
Audi A3 / S3 / RS 3
10-19-2007 12:19 PM
mac0920tt
02-21-2005 07:08 AM
kepstein
07-30-2003 05:54 PM
