RNS-E Aux input active and installed!
The newest Audi nav disc enables an auxiliary input. With a little VAG-Com recoding I did the option is visible in the menus.
The stereo shop that did my entire system tied into the pins on the back of the head unit and ran them to a headphone jack in the console. Now I can connect up anything with a line level or headphone output.
Just picked it up this afternoon, but I am pleased so far.
Pics:
The input jack next to my sub remote gain control.
<img src="http://BrianJA.smugmug.com/photos/316209468_qGmDx-L-3.jpg">
iPod nano connected up.
<img src="http://BrianJA.smugmug.com/photos/316208727_UrjgY-L-3.jpg">
XM Inno connected. xm AND Sirius at the same time!
<img src="http://BrianJA.smugmug.com/photos/316213034_dr5cR-L-3.jpg">
Aux is now in the source list.
<img src="http://BrianJA.smugmug.com/photos/316212240_RFkRu-L-2.jpg">
Aux active.
<img src="http://BrianJA.smugmug.com/photos/316210549_S3tnK-L-2.jpg">
Gauge cluster showing Aux.
<img src="http://BrianJA.smugmug.com/photos/316211285_JaM4B-L-2.jpg">
Pics:
Aux active.
Re: RNS-E Aux input active and installed!
nice. did you purchase the nav disc? also, how does it connect on the back of the headunit? haven't head mine out in awhile so i don't recall what's back there.
I ordered the disc from navteq. There are pins on the back of the headunit that...
are labeled aux left, right and ground. You have to connect to those.
You can either order the parts to attach it through the existing wiring harness or you can direct solder to the pins if you are very skilled with a soldering iron. I gather it is very tight back there.
Re: I ordered the disc from navteq. There are pins on the back of the headunit that...
hmm. not afraid of soldering. did they cut a regular 1/8 jack cable and solder it in? no pics i presume?
i have an ipod adapter setup today from blitzsafe, but it has a background beep noise that drives me nuts. would rather go your route. don't want to pay for the nav discs though. need to find another source on that one.
what's the version number of the nav disc you have?
thanks
thanks
They used a panel mount headphone jack in the console and ran standard audio cable from there...
to the head unit.
It works well.
IDK about another source for the update. I gather that if you can find someone who will let you borrow their new disc you can put it in yours and it will upgrade your nav. Then you can put the old map disc back in.
I'm not sure on that though.
Then you would still need to recode the radio with VAG-com for it to be visible.
It works well.
Re: They used a panel mount headphone jack in the console and ran standard audio cable from there...
that was the other question i forgot to ask. do you have the coding instructions for enabling it?
fenwayfan
21
10-26-2004 07:39 AM
