Tire pressure........on the PS2 it says Max 50lbs
The TPMS depends on what pressures you lock in...
I don't have the manual in front of me, but I think it will go off if it drops a few psi.
So if your car was locked at 45+, it would go off when it reaches 40-42.
I keep mine at 41 all around for a little extra protection on the roads in my area, but I know there are many people who use lower pressures.
Re: The TPMS depends on what pressures you lock in...
at 41psi the front still looks a bit soft and kinda flat....I reset the sensor after I add some air to like 46-48psi each.....not sure if that will be too high.
Ouch ... that's way high, If any thing I'd go down to about 38.
If you're driving with 3 other passengers, 41 psi makes sense, but if it's mostly yourself and one other passenger, around 38 is perfect. On the track you'll drop it even further.
Correct tire pressure=look on door jambs
All cars have their proper operating tire pressures printed on their driver's side door jambs. Check there.
Check tires when they're cold of course.
You can adjust up or down a few psi depending upon direct experience and you can air up a few psi for heavier loads, b ut 50 lbs is way, way too high. I think I run 40 or 41 psi
Regenmeister
10
07-14-2005 03:34 AM
Ming rings in Minn
14
11-24-2004 09:33 AM
spdracer53
04-06-2001 02:18 PM
