Any suggestions for disabling ABS system
I did this on a track under fairly controlled conditions, but would not recommend it for general use. You are correct to want to disengage the system for winter/ice driving if you know what you are doing and would have much greater control with it off, but unlike the switch of days gone by, disengaging the system now has many side effects as it is part of of the ESP system as well.
Additionally, what I experienced when I pulled the fuse on my old B5 S4 was the impact of additional circuits that shared that electrical feed like the "rough road" throttle adjustment. This circuit was part of a system that monitored road conditions looking for rough surfaces and made the throttle sensitivity quite numb to compensate so you wouldn't end up jerking your car with unintended throttle inputs.
I found it to be a serious tradeoff given that I wanted ABS off with *more* thottle sensitivity for the type of driving I had in mind. Your circumstance would benefit from a high degree of throttle sensitivity as well. I can't say for sure that these systems share a common fuse in the B6 series cars, so this may or may not be applicable.
Sadly too many systems are far too intertwined these days to allow us the simplicity of days gone by.....
Sylvain
Remember ABS prevents <b>wheel lock</b>, nothing more. It does <b>not</b> stop you quicker, especially in deep snow where wheel lock will create a "snow dam" in front of each wheel to slow you down. It was never intended nor designed to stop you quicker.
As soon as an ABS system detects wheel lock, it will begin modulating the brakes to prevent it - thats the whole point. You can't steer if the wheel's not turning, and ABS allows you to mash the brake pedal to the floor <b>and</b> steer around road obstacles.
People who believe ABS will always stop you faster somehow are not correctly informed as to what ABS will and will not do for you.
But he is also right, once it detects wheel lock, it immediately overestimates the loss of traction. I stress both "immediate" and "overestimates":
immediate: It doesn't even wait a single sensor cycle to give the driver a chance to fix the problem himself
overestimates: it resorts to a pulse <i>maximum</i> which itself is generally less than than enough to exceed the traction limit. In other words, when it pumps the brakes, it doesn't even pump them enough to lock them up again. This means means
a) there is no point to pumping them at all, just keeping them at that pressure would be better than pumping them to lesser pressures, and
b) it is *never* going to figure out if there suddeenly happens to be more traction (like the snow patch ends) because wheel lock is not part of what's causing it to keep pumping anyway (since there isn't any). The only thing it will do based on future wheel lock is pump even lighter.
But I still don't get why it's bothering to pump at all. It's like their strategy is "back off the brakes so they don't lock at all - but then pump them there anyway in case we made a mistake."
This is, in my sarcastic opinion, one step away from "shut off the brakes if a wheel locks, that way at least you can steer."
