S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
B6 S4 timing tensioner and white smoke from exhaust?
Old Apr 2, 2013 | 04:35 PM
tronno's Avatar
Default B6 S4 timing tensioner and white smoke from exhaust?
hi, i just purchased a 04 S4 cabriolet and its been giving me nothing but trouble and the dealership isnt cooperating. yet at least.
Well my problem here is i notice the car had its oil pressure light coming on with normal driving. but i read into it and found out it might be sludge buildup. so i got some Zmax to help clean it out. and now it only goes off at high rpm and under higher load. Expecting an oil change but the motor will need to be fix anyways..
i noticed a knocking sound from the back of the engine after a long drive so i stopped the car and let it sit. after a while started the car and it went away. made it to the dealership for a diagnostics and they said the timing chain tensioners are going out. the engine started getting random misfires also and cel flashing.
the engine has been smoking a bit since ive got it. seems like white smoke and i can smell fuel when it smokes. i was wondering if the it has to do with the timing being off or something else? so i can decide weather to fix the motor or not.
I need your opinions and expertise. please chime in thanks!!
Old Apr 2, 2013 | 04:49 PM
tronno's Avatar
in addition i did a compression test and my compression numbers were in the 130's
Old Aug 6, 2013 | 02:48 AM
Lion Heart's Avatar
Default Well?
Did you have any luck fixing this in the end, or at least finding out what it was??
I'm really keen to find out (similar issue).
GruvenS4
4.2 V8 Discussion
14
Sep 27, 2018 07:34 PM
Anthony Schwemmer
4.2 V8 Discussion
Oct 29, 2015 05:44 PM
tyzuse9
12
Mar 13, 2013 06:46 AM
jza80
19
Aug 7, 2010 12:29 AM
