help - driver's side window stuck down
That happened to mine. I was able to pull it up by hand while operating the switch
Required quite a bit of fiddling to finally get it up though.
The Audi dealer was able to fix it within a couple of hours of it happening. Something had broken in the regulator.
Re: That happened to mine. I was able to pull it up by hand while operating the switch
Try fiddling with the switch. it may come up a bit. if it does,hit the switch and pull it up. dont let it go down again. It will eventually work to get it up. The regulator needs to be replaced. it happened to three of mine.
This just happenned today as well! :(
Thankfully I'm still under warranty. I was able to get the wind back up in little increments by fiddling with the switch. Going to leave it up until I can get it into the dealer for the 35k mi service.
