Suspension question for those who track...
I am running 570lb spring rates F and R right now with the stock front anti-sway and 24mm rear sway.
I am considering upping the front sway to 35mm but am concerned the front will start to push again as I have finally gotten the car neutral.
I have on order some rear 680lb springs to help even this out but has anyone found going up to the 35mm in front caused more problems in conjunction with the 24mm rear. On the 2003 A4 I had a lot of push from this and on the 2006 A4 I left it stock up front and 24mm rear for this reason. Anyone have data on the B6 S4 for this?
Jet Jockey will steer you correctly.
Tomasz@Startup
09-19-2007 08:33 PM
Tomasz@Startup
09-18-2007 12:15 PM
Tomasz@Startup
09-15-2007 07:13 PM
Tomasz@Startup
A4 (B7 Platform) Discussion
09-15-2007 06:47 PM
EuroDriver
06-29-2005 11:00 AM
