What's the diameter of the Milltek Downpipes?
If that's the case then if you were to buy the Milltek DP's you'd basically...
be buying the same as stock but with high flow cats. And for $1799! I think the piggie pipes would be the way to go, IMO.
Because all you'd getting with Milltek is stock diameter DP's and 200cell cats. Doesn't really seem like a good deal.
If I'm wrong on this subject someone chime in.
I agree, mostly.
For maximum power, we should be using a 2.5" exhaust. See chart below.
<img src="http://pictureposter.audiworld.com/71038/exhaust.jpg">
Most of the other exhaust companies are appropriately using 2.5" pipe tubing. Autospeed Performance, Labree, Fast Intentions and AWE all do so. Using a 2.5" exhaust, you'll also be prepared should you go for the SC when it's released. The smaller 2.25" exhaust will be an even more pronounced restriction then.
Are there any downpipes that are full 3" front to back? why is it they taper of to 2.5" in most kits
vwaudidriver
21
09-14-2004 07:14 PM
gary808
07-01-2004 09:03 PM
ESFO
14
05-23-2004 09:02 AM
