2011 - S4 Options for brake pads ... less dust!?
#11
Banned
You will also need avang.com to change the rear brakes.I believe the electronic Parking brake needs to be reconfigured
#13
So just about had it with the amount of dust that these puppies produce. Spent time over the weekend cleaning the rims, again, as it feels like I have to do every few days, and after an 80km drive the front wheels already looked like crud and today all wheels look crappy.
Car only has 30,000km or so on it, but am starting to look at options. What success have people been having for anyone who has replaced the stock brake pads with respect to finding a set that still offer comparable performance but with significantly less dust!?
Thx!
Thx!
If you do want to maintain wheel looks then the following products are the solution...used in steps laid out;
1) Wheel cleaner...Bilberry (what else...!).
Best to use undiluted initially to remove all brake dusts then dilute a spare 500ml bottle with a 1-part of Bilberry and 4-parts of water. That does me well for regular wheel wash done once a month. A very effective product which is not acid base though do use gloves with all chemicals as a precaution.
2) CarPro IronX (what else...!).
This is an excellent cleaner used for the car body and wheels. It is best used after Bilberry has been used on the wheels. It basically gets rid of metal containments that may not be visible to the eyes and leaves the surface feeling super smooth ready for FK1000p application. I use this once every 12-mths...yeah, it is that effect.
3) Finish Kare 1000p (aka FK1000p)
After all the cleaning you MUST protect the bare paint and for the body and especially wheels FK1000p is a no brainer. An application will comfortably see you through 6-mths...I have tested it on my car used mainly for track. Dust comes off easily once the wheels have been treated. Apply 2-coats 24-hrs apart for best results. I am extra so re-apply every 3-mths. The product comes in a tab which will easily see 5-yrs of use when used only for wheels. It is also excellent for use on the car body...I reckon the tub will still last 3-yurs if use for wheels + body.
The above will give you a very cleaner set of wheels that is easy to maintain if you opt to keep OEM pads or buy a dust free pad.
#14
I installed Hawk Ceramics on the front a week ago. Very little dust, no noise, and a more progressive pedal that is easier to modulate. I'm completely satisfied.
Vijay
RS4 (B7 Platform) Discussion
05-21-2008 06:02 AM
