6MT has a "catch" when shifting into 2nd gear
hi folks!
i've got a 2013 6MT which i bought in december 2016 with 65k miles with current CPO coverage.
i didn't notice it at first, but after a week or so of driving it i realized that if i push the shifter "too far" toward me when shifting into second gear, it seems to catch on something and prevents a clean shift. i've never experienced this in any other manual transmission i've driven - is this common with the B8? it happens both when shifting from 1st to 2nd and also can happen from 3rd to 2nd. so long as i pull STRAIGHT back it has a nice shift. it seems like the shift linkage is getting caught on a sharp corner that should be a rounded corner.
a little more info that might be of interest:
* there is an after market shift ****, but i pulled the center console up and there doesn't appear to be any loose washers or anything between the leather boot and the covered rubber boot, suggesting that the catch/hitch is inside the rubber boot.
* i very recently had the whole transmission & clutch replaced under CPO due to an internal bearing (thank you CPO). the catch/hitch was there prior to replacement and is still there now.
anybody else experience this? i am trying to determine if this is a "known issue" or if i should be able to get my CPO to address it...
thanks so much!!
thanks so much!!
Banned
hi folks!
thanks so much!!
thanks so much!!
B8 S4 6MT shift linkage movement inconsistently good
6MT after a bumpy turn 1st to 2nd and sometimes 3rd to 2nd "catch" when shifting ...it will go away a bit then come back .it happens more often lately
I've dealing with a similar issue...by any chance did you resolve the problem
hi folks!
thanks so much!!
thanks so much!!
Bazzy
04-27-2021 06:28 AM
rootkid
9
03-26-2003 01:09 PM
s4rocket
06-19-2001 09:04 PM
paul_858
06-02-2001 11:36 PM
