Dyno results - 2010 DSG S4 100 tune, 034 HFC's(junk), miltek non-res, various intakes
Stock intake:
345WHP 323WTQ
342WHP 331WTQ
343WHP 320WTQ
Strat intake:
341WHP 305WTQ
340WHP 306WTQ
The strat runs were made one after the other... next day runs with the stock intake were made one after the other... Not sure why it lost so much TQ? Stoked to get the car redynoed on Monday with the pulley and software... The pulley went on today but the ecu won't be back until Monday and I will pick up the car Tuesday... Kind of sucks because the weather is going to be very good today for drag racing... Oh well...
PT...are you seriously going to bother with the APR? The aftermarket intakes for the 4.2 S4s was also shown to do little to nothing (in fact it hurt as it's design allowed it to eat hot air from the engine bay and one of the auxillary radiators)
I'd save the few hundred dollars.
Let's see more data before making a conclusion.
Stock intake:
345WHP 323WTQ
342WHP 331WTQ
343WHP 320WTQ
Strat intake:
341WHP 305WTQ
340WHP 306WTQ
This makes me not want an intake now. What about the gains posted by APR with their tune? The intake apparently adds up to 15awhp.
What you just said makes no sense at all. Freer flowing air on the intake side is not going to rob the car of power or down low torque. A poorly designed one that maybe let's heat in, or eliminates audi's brilliant pressurized design might though.
Anyway, for the entertainment of this forum, please explain the following
1. How a 'freer flowing' intake will rob a car of power if there is a bad downpipe/cat design on the exhaust side.
2. What data are you looking for? Here we have an independant dyno from easily the most stand up, experienced guy in the entire b8 subforum.
Stock intake:
345WHP 323WTQ
342WHP 331WTQ
343WHP 320WTQ
Strat intake:
341WHP 305WTQ
340WHP 306WTQ
Sorry, carry on. Looking forward to more results, especially independent ones.
i really couldn't care less if the strat intake get hot air from engine bays when the car is stopped.... but if it's a concern, i'd get this :
http://www.thermotec.com/products/14...at-shield.html
seems a cheap mod to ensure more cool air.
p.s. i have nothing to do with Stratmosphere, just wanted to express my opinion
You are smart enough to understand this without my explaination, but apparently you can't be bothered to go check the thread about this yourself.
Second, as I asked, please go see Ron's own issues on the 034 thread which is shorter but as entertaining as the MTM thread Voltron had. The diameter of the "HFC" is too small, and under chipped cars with high RPM - you know, where the boost normally bleeds off - they start blocking exiting airflow and rob the engine of power.
There is not magical place for air to go, it's a straightforward path. If you are getting more air with a freer flowing intake, there is more to compress, higher amounts of boost, and hence air make it into the cylinders. That exhaust has to go somewhere, so more air sooner will only cause the issues seen with the "HFC's" to show sooner. The sooner the exhaust gas get restricted exiting the engine, it will rob the car of power.
After 034's are off, if Ron runs this same test I'd be willing to bet the power is back with Strat over stock - as Faba4b8 says, John has dyno readings to support this on stock, so as you said yourself above, only applied to the exhaust, explain how a "freer flowing exhaust" (i.e. 034's HFC's) can make less power? Ron already illustrated this in his 1/4 mile and dyno runs over the STOCK cats.
Answer: It's not freer flowing.
1. Where does the B8 S4 make peak torque? IIRC it's closer to idle than it is to redline. So why are you talking about a high rpm restriction? Engine speeds aren't going to see the 034 cat being a problem where the S4 makes peak torque (2-4k RPM).
2. The other data we have (primetime's dragracing slips) bear this out...he has no down low problems with the cat AT ALL as is evident by his good launches and first half times. The supposed restriction causes trouble at high rpms...which is again irrelevant to these dyno numbers that show a problem making peak torque at low RPMs.
3. Don't forget that in the two tests Ron had the 034 cats on for both dynos. The only change was the airbox...Audi vs. Strat...so you need to explain why a suposedly freer flowing Strat INTAKE is going to cause a loss of low end torque. The car dyno'd the same peak hp (close enough) with both airboxes in...but lost about 20 WTQ with the strat box.
Telling me to go read a thread on AZ (that I've already read) isn't going to get you out of explaining something you posted that was dead wrong. I asked you to explain so you could show the forum what you know (or don't know)...not for my own edification.
