Fueling Problems - Help Please?
My 2012 S4 felt like the transmission was slipping yesterday. I ran a VAG-COM scan and found fault codes for misfires and fuel pressure. Rather than drive the hour+ to the nearest Audi Dealer, has anyone seen these codes before and know what I need to check/fix/replace?
Thank you in advance for any help and advice.
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H08 0003
Revision: --H08---
Coding: 0104000A240F0128
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: 326137D165BDD2D4E1-8066
9 Faults Found:
7113 - Cylinder 1
P0301 00 [096] - Misfire Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
Engine speed: 1983.00 /min
Normed load value: 60.4 %
Vehicle speed: 5 km/h
Coolant temperature: 35 °C
Intake air temperature: 27 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.101 V
Unlearning counter according OBD: 39
Engine speed: actual: 2016 /min
MAF_ENVD: 468.44705 mg/stroke
Coolant temperature (unfiltered): 35.3 °C
Engine: operating status: PL
T_AST_ENVD: 25.70 s
Vehicle speed: actual: 5 km/h
7117 - Cylinder 3
P0303 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
T_AST_ENVD: 25.70 s
7115 - Cylinder 2
P0302 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
T_AST_ENVD: 25.70 s
6371 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
Engine speed: 2055.00 /min
Normed load value: 60.8 %
Vehicle speed: 6 km/h
Engine speed: actual: 2048 /min
MAF_ENVD: 490.23528 mg/stroke
T_AST_ENVD: 25.70 s
Vehicle speed: actual: 6 km/h
6137 - Oxygen (Lambda) Sensor B1 S1
P0133 00 [096] - Response too Slow
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188443 km
Date: 2018.09.10
Time: 17:40:37
Engine speed: 1754.00 /min
Normed load value: 25.1 %
Vehicle speed: 87 km/h
Coolant temperature: 75 °C
Intake air temperature: 21 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.812 V
Engine speed: actual: 1728 /min
MAF_ENVD: 201.54117 mg/stroke
Coolant temperature (unfiltered): 75.0 °C
T_AST_ENVD: 154.20 s
STATE_LS_ENVD[1]: 2
6238 - Fuel Rail/System Pressure
P0087 00 [032] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188443 km
Date: 2018.09.10
Time: 17:40:20
Engine speed: 1776.00 /min
Normed load value: 76.9 %
Coolant temperature: 69 °C
Intake air temperature: 19 °C
Voltage terminal 30: 13.710 V
Unlearning counter according OBD: 38
Engine speed: actual: 1760 /min
MAF_ENVD: 637.30587 mg/stroke
Coolant temperature (unfiltered): 69.0 °C
FUEL_MASS_REQ_I_CTL_ENVD: 7.851563
FUP_ENVD: 10868.1416 hPa
FUP_EFP_ENVD: 4773.4 hPa
9537 - Fuel Pressure too Low during Cold Start
P053F 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:00
Engine speed: 834.00 /min
Normed load value: 36.9 %
Vehicle speed: 3 km/h
Coolant temperature: 27 °C
Voltage terminal 30: 12.593 V
Unlearning counter according OBD: 40
Engine speed: actual: 1632 /min
MAF_ENVD: 403.08234 mg/stroke
Coolant temperature (unfiltered): 29.3 °C
FUEL_MASS_REQ_I_CTL_ENVD: 50.250000
FUP_ENVD: 25811.8363 hPa
6208 - Fuel Trim; Bank 1 (Mult)
P1128 00 [101] - System too Lean
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188455 km
Date: 2018.09.10
Time: 17:48:51
Engine speed: 1633.00 /min
Normed load value: 34.5 %
Vehicle speed: 81 km/h
Coolant temperature: 96 °C
Voltage terminal 30: 13.913 V
Engine speed: actual: 1600 /min
MAF_ENVD: 272.35293 mg/stroke
Coolant temperature (unfiltered): 96.0 °C
T_AST_ENVD: 642.50 s
STATE_LS_ENVD[1]: 2
7948 - Cylinder Disabling
P130A 00 [040] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
Engine speed: 1961.00 /min
Normed load value: 48.2 %
Vehicle speed: 13 km/h
Engine speed: actual: 224 /min
MAF_ENVD: 419.42352 mg/stroke
Coolant temperature (unfiltered): 39.0 °C
Engine: operating status: ST
T_AST_ENVD: 0.00 s
Vehicle speed: actual: 0 km/h
Readiness: 0000 0000
Revision: --H08---
9 Faults Found:
7113 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
T_AST_ENVD: 25.70 s
7117 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
T_AST_ENVD: 25.70 s
7115 - Cylinder 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
T_AST_ENVD: 25.70 s
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
T_AST_ENVD: 25.70 s
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188443 km
Date: 2018.09.10
Time: 17:40:37
STATE_LS_ENVD[1]: 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188443 km
Date: 2018.09.10
Time: 17:40:20
P053F 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188455 km
Date: 2018.09.10
Time: 17:48:51
STATE_LS_ENVD[1]: 2
P130A 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188464 km
Date: 2018.09.11
Time: 06:47:40
T_AST_ENVD: 0.00 s
Did you fix your issue yet? I would check your fuel pump/control module and or injectors as a possible cause. I would lean more towards the fuel pump/control module due to the low fuel pressure and lean condition codes
