View Poll Results: Have you experienced A/C odors?
Yes, and I found a permanent solution
5.88%
Yes, and I do not have a permanent solution
11.76%
No
14
82.35%
Voters: 17. You may not vote on this poll
How many people have had A/C odor issues?
Hi all,
I've been researching the various reports of a/c odors in Audi's, and was wondering how many of you have experienced these problems. Just trying to get a feel for how prevalent this problem is.
If you did have this problem, were you able to find a permanent solution, or just band-aid fixes?
Thanks,
- Ryan
Thanks,
- Ryan
Hi all,
Thanks,
- Ryan
Thanks,
- Ryan
I just responded 'no' but then i realized i haven't run the AC yet! Sorry.
Yea, when I turn on the AC, I get this pungent whiff immediately after. There was another thread saying to run your heater on high to dry out the system and eliminate the bacteria. I haven't tried this yet, but it seems logical.
Banned
GUYs. This is a common problem with many cars and a simple solution to make it go away and stay away. The smell is from bacteria and mold growing in the moisture of the HVAC system. IF you have the problem, first run the heater on high at the highest temp and fan setting to dry out the system. Then buy a can of Lysol aerosol spray. With the A/c on at full blast, set the HVAC to take in air from the outside of the car. Find the air intake that is usually located near the windshield wipers. Dispense 1/2 of the can into the incoming air intake. That is what your dealer will most likely do if you take it back for service. That should last about a yr or so. Repeat if necessary. Perhaps someone can help me out with the exact location of the fresh air intake on the B8.
Also helpful is to turn the A/C off and just let the fan blow for several minutes before you reach your destination. This will help clear out the moisture.
My roommate with a B7 2.0T had this issue too. It is common for all cars with A/C ( so all cars )
Good luck, I know that smell can be unpleasant.
So, does this issue seem to be more prevalent on Audi/VW? Or am I just being paranoid? I've had Honda and Toyota for years and never had a problem, but the one person that I know with a VW has this issue.
Admittedly, I am spending more time on Audi forums, but searches seem to turn up more here that others.
This water doesn't always make it's way totally down the drip line to the ground, and as pointed out can make a nice cool, dark place for nasty smelling things to grow in. Don't use the AC button unless needed and this won't really ever be a problem.
