Shuffling on jukebox and SD CARD max size
Deleted files until I got to 3900 and something files and the problem went away.
I use a command-line tool "ffmpeg" to do this, you can PM for details. I'm sure there are more friendly programs out there.
It doesn't happen often but it is pretty annoying. The only way to fix it is to re-encode/rip the mp3 with different settings or a different encoder. It seems like something is broken in the MMI's playback code.
You have to format the SD card to FAT32 (You will probably have to download an aftermarket program like FAT32Formatter), and you also have to make sure all of your songs are in separate folders (maybe the album folders under a larger Artist folder). Voila'! You can probably store your entire music library in your car.
