Anti Laser Cabin Control Set Module Install
Hi All- If anyone has installed an anti-laser ("parking assist") system in their S4-B9, could they share photos of their installed control set? I'm curious to see what options others have considered; on the center console, on the dash, at the driver's thigh, or who knows where? Thanks in advance. Jack.
What system will you be running?
You can have it tucked into the storage compartment under the headlight ****. It is deep enough with openings towards to the rear to have a concealed fitment. Otherwise, the standard fit to the driver's thigh or underneath the steering column (away from the knee airbag) would work.
See more here: https://www.rdforum.org/index.php?threads/84873/
Daaavid- Thanks for the reply. I'm considering either the AL Priority system or a TMG system (which looks like a screaming value). I've lurked in RDF for awhile [prior to buying a Uniden R3 (which definitely earns it's keep!)]. With this particular post I am hoping to see some actual installs. Ideally, I'd like the control set within reach; so the headlamp storage area wouldn't work. Perhaps a surface mount beside/above the ignition with wires thru the HVAC... Jack.
future S4
A4 (B9 Platform) Discussion
19
04-02-2019 03:16 PM
Larry H
VAG-COM Discussion
01-16-2006 11:06 AM
Terri Schiavo
18
11-08-2004 07:17 PM
Fuzzy Wilson
10-05-2000 07:05 AM
