Can I connect battery charger through DC
I just purchased a battery tender plus charger. I live in Connecticut. The car has summer tires on it and I don't see my moving the car until March(ish)anyway. Can I safely connect the charger through the DC (cigarette lighter) type plug found in the trunk of the car? Do I need to keep the trunk open to vent? Thank you much.
Are you sure? Just inside the cubby on the right side. I don’t know if it’s powered or not when off. Is it possible it might work for purposes of charging the battery even if it is not powered when off?
That's how Porsche outlets work. They stay live for a while and when you plug in the charger within that time frame, it keeps working. Having said that, I know the receptacles in my S4's have not been live since my 2010 B8 but I will go look for the one in the trunk (if I find it) and see if it's live.
I use a battery tender via the jump start points in the engine department.
I ended up using the eyelet type jumper wire(s) that came with the charger hooked directly to the battery posts in the trunk. Wire runs through the compact spare tire and exits out from under the trunk mat at the rear of the trunk.
This really is the only proper way to connect a battery tender to a vehicle.
angrypengu
A8 / S8 (D5 Platform) Discussion
52
04-01-2023 05:47 PM
Roger @ CA
Mid Atlantic Discussion
9
12-14-2007 07:24 AM
