Is it a 2mm clearance between the rim and the caliper to small?
He was asking how old are your pads because if they are new then that is plenty of clearance
However, if you are measuring 2 mm after you have put 30k miles on your pads then they would have worn substantially and this would affect your measurement. As your pads wear, the gap between your brakes and your wheel increases. So, if you measured this gap with brand new pads installed, chances are you are fine...Hope that helps.
Swank4
9
07-25-2007 03:12 PM
Younger
10-13-2005 06:27 AM
blazin S4
07-21-2005 08:24 PM
Aldous
08-14-2002 04:16 PM
