Another ?. What kind of wire is used for the City light? The clip end I am talking about. Right city
light is not working and I want to replace with another to fix that problem.
I'm sure. It worked then it flickered now it no longer lights up. I bought the city light kit from
AWE and I think when the wires from the kit are just a little to short. NOt to bust AWE about that, but about 1-2" more would have been better.
Before you go replacing wires, swap bulbs to make sure the bulb is not the problem...
If the wire is actually too short, this could be tricky
Once the clip (on the end of the wire) is in the connector, it's not easy to get out...I'm not even sure how you would do it. I guess you would have to cut the wire, make sure the clip is well seated in the connector, and then splice in an extra piece of wire. If so, you don't need any special wire...just make sure you have the same guage, and you'll be fine
Sorry for the bother, which set of directions should I Use the link or the other one, any difference
MNCK-82-S4
07-08-2004 03:18 PM
TTTEXAN
05-04-2004 03:29 AM
2low4snow
03-09-2004 01:05 PM
denic992-- JAYHAWK
12-26-2003 06:53 AM
US RS4 ;-)
05-23-2001 06:02 PM
