Any companies ever made ceramic turbine blades?
seems to me it might be usefull. Since the turbine blade gets hotter than the impeller, a material more heat resistant would be good. Plus there is no impact to worry about from objects so material ductility isnt an issue.
im also guessing the turbine fails more often than the impeller.
I'm no turbine expert...
but I would guess that most ceramics are too brittle. They've got the whole inconnel thing down pat and the working temperatures of Nickel-based superalloys seem to be creeping up every year.
you might be surprised what ceramics can do these days, they have advanced also (edit)
plus they dont have as big a fatigue issue as metals i believe.
im not saying it would definitely work, just throwing the idea out there.
problems with ceramic is overspeed..
if they overspeed for any prolonged amount of time or repeated times, they will break. inconel is much much stronger in the overspeed issue.
It's definitely something to ponder...
I'd have to first study the prevailing failure modes of traditional turbine wheels to see how much benefit could be gained through ceramics.
Also, a high temperature differential is favorable on the hot-side of the turbocharger...so a ceramic turbine assembly may actually impede the spool up by not retaining heat.
sure, but do you want to pay $15k for a turbo?
some of latest jet engines use single crystal super-alloy blisks (or bladed disks). Undoubtably these types of things costs quite a bit.
yes i have heard of that, growing the blade from a single crystal
so there are no slip planes and the strength is determined by the atomic bonds. When the technology becomes mature perhaps it could be used in cars.
