Boost surging and N75 Valve replacement / adjustment
Just thought I would share my experience with boost surging and adjusting/replacing the N75 to cure this problem.
I was using a 1.3 bar Neuspeed chip program and the car was running great. It went in for an RS4 clutch replacement / rear main seal R/R back in January. I've been driving the car pretty easy for the past month breaking the clutch in. Recently (driving the car harder now) I noticed that the boost would peak about 1.2-1.3 bar then drop to .8 bar, then back to 1.2 then drop to 1.0 and then back to 1.2, you get the picture (surging).
After searching the archives, I found that the culprit may be the N75 valve. I didn't even mess with adjusting my original (84K miles on it). I purchased a new one and installed it (very basic install). I test drove the car however the surging was still present.
I marked the "factory" position of the screw on the N75 with a Sharpie. I then turned the screw a 1/4 turn clockwise. Miraculously, this fixed my surging issue, however I was only boosting about 1.1 bar tapering to .9-1.0 I then marked this position and adjusted it back an 1/8 of a turn counter-clockwise. The car runs perfect, 1.3 bar tapering to 1.1
Thanks to VonK and others who have posted about the N75 and explained how it works with the 2.7T engine. I found these posts very informative and it saved me a lot of time troubleshooting this issue.
zapco was one of the , if not the 1st to post that info here
afaik
I like how vonk always summarizes what everyone else has already posted and gets credit for it hah
oh well pointless post
When did Neuspeed come out with their 1.3 bar chip? Have any logs?
Also, does Neuspeed have a policy about trying the chip prior to purchase like other tuners? I'd love to compare the chip to X
Could you be experiencing throttle cut? WOLSCOD and I are running a protoype solution...
to throttle cut which is working fantastically. It allows you to control the boost spike precisely and it eliminates hesitiation.
