Calling all knock gurus: Is there a direct correlation between retard and knock voltage??
Beteween midgets and retard, yes...
There is a strong correlation between knock voltage and timing retard, but not direct. If you begin to saturate the sensors, the ECU will check other parameters and dial things back if necessary.
If you're hitting 29+V, timing will be pulled.
