Can fault codes (DTCs) clear on their own? I had some, left them there, went back and they are gone?
Re: Can fault codes (DTCs) clear on their own? ...
Yes, there are "soft" and "hard" DTCs. A soft DTC will drop off after a certain number of cold start cycles if the error does not re-occur. Perfect example is the code that will be set if you don't tighten the gas cap securely. OBD-II will think there is a fuel system leak and set a code. Go through a couple of cold cycles with the cap secured correctly and the code will go away.<p>donp - '00 S4 Silver/Silver
<a href="http://audizone.com">audizone.com</a>
i heard about 7 "hard codes" from dynoday
<p>-Cheng
<a href="http://registry.audiworld.com/audi/registry/details.asp?car=5226"><img src="http://www.musicsend.com/myS4.jpg" border= "0"></a>
can someone say PULL THE NEGATIVE BATTERY CABLE! ;-)
<p><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/carssmall4.jpg">
00 S4 tip
Silver/Black
GIAC ECU/tip chips
V1
00 S4 tip
Silver/Black
GIAC ECU/tip chips
V1
Flats
07-13-2015 11:23 AM
velosouljah
11-17-2008 05:56 AM
