Can someone give me the part number for the OEM airbox top? TIA.
Here is "my" RS4 parts and part number list . . .
Thanks to Don Istook for most of this . . .
Thanks to audis4guy and to whoever gave me ETOS
RS4 K04 Turbocharger, left 078 145 703 M (5304 988 0025)
RS4 K04 Turbocharger, right 078 145 704 M (5304 988 0026)
induction pipe RH (Turbo inlet pipe) 078133610H
induction pipe LH (Turbo inlet pipe) 078133609H
induction pipe RH (up-pipe) 078133610G
induction pipe LH (up pipe) 078133609G
induction pipe connecting hose - 2 078 145 719 P
clutch throwout bearing 01E 141 165 B
*RS4 MAF sensor-bosch 077 133 477 K * bad #
Actual housing says 077 133 471 K
Refurbed S6/S8 MAF 077 133 471 KX
RS4 Airbox 078 133 837 BQ
RS4 Airbox-MAF housing O-ring N 909 643 01
MAF housing Torx head screws - 2 N 104 541 01
RS4 fuel pump 8D0 201 319 C
ETOS SAYS 8D0 906 087 AL
RS4 Y-pipe 078 133 351 F
RS4 maf-y-pipe hose 078 129 627 P
RS4 Y-pipe to inlet pipe hose-left 078 133 241 G
RS4 Y-pipe to inlet pipe hose-right 078 133 241 H
turbo-downpipe gaskets - 2 8D0 253 115 F
thick copper gaskets - 2 N 013 814 4
thin copper gaskets - 4 N 013 818 2
coolant line crush gaskets - 8
turbo-downpipe nuts - 8 N 903 690 01
turbo-downpipe studs - 8 N 907 787 01
turbo oil line gaskets - 2 058 145 757 B
rs4 fuel injectors - 6 078 133 551 BJ
small silver washers - 4 N 013 807 6
exhaust manifold to turbo gaskets - 2 078 145 039
injector clips - 6 077 906 037 A
silicone intake o-ring - 2 078 133 148E
From audis4guy
Pressure Control Line:
1pcs N90183603 Banjo Bolt
2pcs N0138076 Sealing washer
Coolant Supply & Return Lines:
1pcs N0210742 Banjo Bolt
2pcs N0138149 Sealing washer
Oil Supply Line:
1pcs N0210715 Banjo Bolt
2pcs N0138182 Sealing washer
<img src="http://66.134.70.69/files/audi/120-2072_IMG.JPG">
From audis4guy
Oil Supply Line:
Rino
02-15-2007 07:49 AM
MoBrazen
52
07-20-2003 07:33 AM
Funkweasel
31
06-12-2003 11:51 AM
Nogaro Baller
03-27-2003 05:27 PM
