cleaning the engine bay.
Do it yourself. ITs easy, just buy GUNK at a local auto part store....
Spray it on the main parts that are dirty. LEt it sit for a few minutes then scrub with a coarse brush and finally rinse. You dont want to spray high pressure towards the intake other than that its cake! Good luck. Don;t clean when engine is hot and run engine after to evaporate the water.
I would NEVER use that stuff on a modern engine. It is HORRIBLE on plastic parts
The petroleum distilates in that stuff are too strong, and will leave a cloud on plastic. Simple Green or some other stuff, spray on, wipe off. With all the electronics on these cars, why do you want to get it wet? You hose out the inside of your PC at home?
Check the detailing forum
Do it yourself, here's how...
<ul><li><a href="http://www.carcareonline.com/clean_engines.html">How to properly clean your car's engine compartment.</a></li></ul>
johnd64
04-27-2019 07:37 PM
