Driveshaft failure question...
I'm trying to track down the source of a drivetrain clunk when shifting or quickly accelerating/decelerating and the symptoms (and my mechanic) seems to suggest it could be the driveshaft. Upon removing the driveshaft, would it be obvious that it is failing? What am I looking for?
Diff had a ton of play in it and I just replaced it with a used one from Shokan. Even after 3 shops recommended this - I don't think this was the answer.
Other notes:
Diff mounts have all been replaced.
Control arms/bushings are fine.
The other day I had my ESP light come on while driving straight in very light rain (no puddles) and shortly thereafter, had the car pull hard to the right for no apparent reason. I don't know the relevance, but the ESP light has never come on before and this car has always tracked straight as can be.
Any suggestions or help is greatly appreciated.
2001 6MT
TIA - Dave
Other notes:
2001 6MT
TIA - Dave
Sound really seems to be coming from the center/rear of car...
wouldn't that rule out the motor mount? Based on where the sound was coming from, I never considered it could be a motor mount.
Thanks for the input.
Installed Stern bushings and the street series ASP diff mount...
to get rid of the excess driveline movement. These helped...a little. After installing these, the clunking was more pronounced and that's when I was told the diff was shot.
Noise appears to be coming from the general location of the diff mount, however.
Feel like I'm just throwing money at it at this point because none of the shops I've visited can diagnose it.
Thank you.
Thank you.
I assumed the shop that replaced the diff would have, but maybe not...
Guess it's another thing to check. So many things happened at once I don't even remember where I started. Initially it was the driveline slop that I hoped to cure with diff mounts, diff bushings and the DTS. This just seemed to aggravate matters.
The vibration/clunking/diff whine became exagerated so I took it to the first shop. They said they thought it was the diff and told me to get a second opinion. I had them replace my rear brakes while it was there. Took it to shop 2 and they gave me the same answer...and replaced a wheel bearing that was bad. Took it to the dealer and they confirmed the diff was toast, so I ordered a used one from Shokan and had shop 2 install it. Still have some vibration (albeit less) and clunking.
Thanks for the input all.
