Dronnell M-10 gurus: what bolts and spacers needed to properly run on an S4?...
AudiWorld Expert
sold the wheels this week...want to make sure i get the proper info to the buyer.
thanks!
thanks!
stock bolts. can't use spacers. can't use the wheels on stock brakes. they don't fit
the dronell M-10's won't clear the calipers of the stock brakes. the stock brakes stick out 5mm too much. the wheels fit totally flush with the fender already, so if you try using a spacer to make the wheels fit, then you'll destroy your front fenders the first time you take the car out.
IIRC...
When I was going to buy 007 m-10s a while back it was rec that I run a stoptech kit or comparable to fit the m-10s up front, or shave off a lot from the stock caliper, but for the most part spacers are not going to work... like Waseem//TMK said. good luck...
those wheels are AWESOME! I love wheels, as ev1 knows on this board!
imolamtmS4
11-23-2005 12:52 PM
Blau Flash
Wheels & Tires Discussion
11-25-2004 04:21 PM
myroad
Audi allroad
22
04-07-2003 04:47 PM
